Electric fence charger circuit diagram
Source: InternetPublisher:王达业 Keywords: charger battery power Updated: 2020/12/01
![12.jpg](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/f62b28028b25935899998e370c8e4961.jpg)
Any good power transistor can be used in this circuit. Adjust the base resistor to obtain a pulse repetition rate of 50 pulses per minute. The value range given can be increased from 10 pulses to 100 pulses per minute. Each support pole of an individual fence line must be insulated and must be installed low so animals cannot crawl underneath. When the unit is working, two neon lamps glow.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- A very convenient small power supply circuit to share
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- How to use SBR to improve power conversion efficiency
- A small and easy-to-make fast charger
- LM317 regulated power supply
- Production of backup power supply for cordless phone
- Circuit diagram explanation: simple switching power supply circuit diagram
- Detailed explanation of mobile phone charger circuit diagram
- Use TL431 to make a simple charger circuit
- Overheat protection circuit schematic diagram
- Using a single transistor to build a smart battery charger circuit diagram
- Fully automatic nickel-cadmium battery charging circuit composed of LM7806
- Battery charging circuit with reverse connection displayb
- Simple dry battery constant current charger circuit
- Charger and adapter power supply circuit design
- 9V charger with preset charging termination voltage
- Electric moped charger
- Parallel fully automatic pulse charger
