Noise box circuit 5
Source: InternetPublisher:ohahaha Keywords: Power supply other power circuits Updated: 2020/12/15
![Noise box circuit 5](http://www.eeworld.com.cn/circuit/upload/fceeb92389e16b271b878c330086b7dd/cad7b49446c5f6d2be41349accb2b0c4.gif)
Circuit description: Transistors Q1 and Q2 amplify the input signal. When used on an electric guitar, the input is overloaded because the gain is too large. RV1 adjusts the amount of existing feedback and enhances the voltage gain so that the output is equivalent to a square input signal. The number of squares will change with RV1.
- Analysis of the working principle of switching regulator
- How about the boost converter TPS61299?
- Using Lead-acid Battery as Power Source for Walkman
- Step-down power supply for driving relays
- Op amp power supply decoupling bypass measures
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Miniature polarity reversal power supply using MAX1721
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- Power supply circuit that can reduce LM317 ripple
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
