Noise box circuit (1)
Source: InternetPublisher:通通 Keywords: Diodes power supplies and other power circuits Updated: 2020/10/14
Circuit Description: The input signal is amplified as it passes through the transistor. The distortion output is then clamped by two diodes and the high frequency noise is filtered by the circuit via a 500pF capacitor. Under normal circumstances, a 1M sliding rheostat adjusts the noise from maximum to none.
- The basic principles of power supply design. What are the key components of a power supply?
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- LED Driver ZD1680
- Miniature polarity reversal power supply using MAX1721
- Power supply circuit that can reduce LM317 ripple
- USB power socket using the car battery
- Detailed explanation of mobile phone charger circuit diagram
- Noise box circuit (1)
- Analysis of various power supply filter circuits
- Rectifier spike absorption circuit
- Acousto-optic digital level detector circuit diagram
- Object presence and displacement detection circuit
- Mobile phone shielding circuit that can be used as a charger
- PLC input and output wiring a
- Internal structure of MC1411 series Darlington current driverc
- Diode spark suppression circuit b
- Fast response circuit b when controlled by transistor
