Internal structure of MC1411 series Darlington current driverc
Source: InternetPublisher:狂妄火龙果 Keywords: Current driver diode signal light Updated: 2020/11/15
Darlington current driver has the advantages of small size, consistent parameters and high reliability. It is especially suitable for high voltage and high current
peripheral drivers. It can directly drive loads such as relays and signal lights . It has built-in Freewheeling diode ensures
safe connection with inductive loads. The internal structure of
the MC1411 series Darlington current driver is as shown in the figure
- Which one is better, NPN or PNP transistor?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- How does a series arrangement of Zener diodes affect the electrical behavior?
- FPGA Features and Architecture
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Simple Wired Spy Bug Circuit Built Based on IC741
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How to build a triangle wave generator using an op amp and discrete components
- Structural diagram and function of sliding resistor
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- VEMD6010X01 reference design circuit | PIN photodiode application circuit
- Acousto-optic digital level detector circuit diagram
- Intrinsically protected safety op amp
- base amplitude modulation circuit
- High frequency signal input switch circuit b
- High frequency signal input switch circuit a
- Tuning circuit composed of TA7335P
- One of the non-contact proximity switch circuits
- Fast response circuit a when controlled by transistor
- Diode dimming circuit
