LT3755 driver LED application circuit diagram
Source: InternetPublisher:newrudeman Keywords: LED circuit LED application circuit diagram Updated: 2020/12/21
The voltage feedback pin of this circuit, referenced to ground, serves as the input to numerous LED protection circuits (such as open LED protection) and allows the converter to function as a constant voltage source. A frequency adjustment pin allows the user to set the frequency from 100kHz to 1MHz to optimize efficiency and performance while minimizing external component size. If external synchronization is required, the LT3755-1 can be selected, whose frequency range of 100kHz~1MHz can be synchronized to an external clock.
![LT3755 driver LED application circuit diagram](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/7df531ab821fec307cb85d50c9b1f4c9.jpg)
- TEC laser diode driver circuit
- DIY a hat with a programmable LED display
- Design and production of a practical electronic counting device
- Use NE555 to make a lighting and sound changing circuit
- Electronic massage and acupuncture device circuit
- Transistor storage time test circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- Three-way music lantern circuit
- Frost alarm circuit
- Simple sensor alarm
- Common double-tube energy-saving lamp circuit schematic diagram
- 8W LED driver application circuit diagram (input voltage is 85 to 264V)
- LED energy-saving lamp circuit principle circuit diagram
- LT3755 driver LED application circuit diagram
- LED indicator integrated circuit circuit diagram
- Novel solar LED light controller circuit diagram
- LED lighting circuit diagram in refrigerator
- MIC2298 driving LED circuit diagram
- Constant current drive LED circuit based on LM2734
- NCP1014/1028 driver LED circuit
