SIPMOS transistor control circuit diagram using photoelectric isolation
Source: InternetPublisher:睡不醒的小壮 Keywords: sipmos optical isolation transistor analog circuit Updated: 2021/12/22
The input end is connected to ground through resistor R2, so that its output end is still open when the power supply voltage drops to 4V, that is, the two push-pull output transistors remain in the off state. This allows the photocoupler output side to remain low when the power supply voltage rises to about 3V, so that the following six inverters 4049 can control the SIPMOS transistor. During the working phase, the output terminal of the optocoupler is open, so that the output terminal of the six-inverter is high level and the output terminal is low level.
![SIPMOS transistor control circuit diagram using photoelectric isolation](http://www.eeworld.com.cn/circuit/upload/ce7f16b63456d4e365a44caa6050ddfe/1a1718012e169a6036bb041acf3fa08c.jpg)
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How to read resistor color codes? Resistor color codes illustrated
- What are the types of commonly used batteries?
- What is the difference between CPLD and FPGA?
- Transfer characteristics of BJT, how to apply Shockley equation?
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to install the accelerometer
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- How to read amplification circuit diagram
- Humidity detector circuit
- Monostable circuit diagram
- Infrared remote control relay circuit a
- Transistor controlled rectifier circuit c
- Paper tension control circuit
- Transistor withstand voltage measuring instrument circuit d
- Distributed parameter microstrip circuit
- Bridge motor drive circuit
- Thyristor trigger circuit with photoelectric isolation
