LED light circuit diagram
Source: InternetPublisher:supremeOne Keywords: led lights led circuit led circuit diagram Updated: 2021/03/08
The picture above shows the maximum number of LEDs that a 555 timer can drive.
The voltage drop of a white or blue LED is 3.2 to 3.6V, so only 3 LEDs can be connected in series.
Capacitors from 10u to 100u are used to control the speed of the pulses.
The lamp holder is made of 8*8 hard board, with nails nailed on all four sides. Fix the base of the IC to the board.
Solder the pin wires of the IC base according to the circuit diagram.
Connect every 3 LEDs in series, paying attention to the polarity.
- TEC laser diode driver circuit
- Example of LED AC drive circuit
- Low cost LED automatic emergency light circuit
- LED Flasher circuit using 2 transistors for LED switching
- Infrared detection alarm
- Gas flameout alarm circuit
- One of the circuits that control one light in multiple placesb
- Frost alarm circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- Small current anti-theft alarm circuit
- Capacitor step-down LED drive circuit diagram using varistor
- Common double-tube energy-saving lamp circuit schematic diagram
- LED energy-saving lamp circuit principle circuit diagram
- Voice controlled flash LED light circuit diagram
- SAA1064 serial I2C bus LED dynamic driver interface circuit diagram
- LED lighting circuit diagram in refrigerator
- LED voltage measurement circuit diagram
- LT3783 boost configuration driving LED circuit diagram
- Circuit diagram of white LED driven by LTC3543
- R1211 driving white LED circuit diagram
