Circuit design using TC35I wireless data transmission and GSM communication module
Source: InternetPublisher:MartinFowler Keywords: power communication power supply communication Updated: 2020/06/09
Wireless data communication circuit design
Wireless data communication circuits are mainly responsible for the short-range wireless data exchange between motor vehicles and fixed base station systems. It consists of core chip nRF401 and its accessory components. nRF401 is a dual-channel, high-performance, low-power dedicated wireless communication chip with an operating frequency of 433.93/434.33MHz. The operating voltage is 3.3v and the maximum communication rate is 20kbps. It can be directly connected to the serial port of the microcontroller for asynchronous communication to achieve Data sent and received. No need to encode the data. The data input terminal DIN is connected to the TxD terminal of the microcontroller, and the data output terminal DOUT is connected to the RXD terminal of the microcontroller. In this circuit, the communication rate is designed to be 19.2 kbps. The circuit principle is shown in Figure 3.
![Circuit design using TC35I wireless data transmission and GSM communication module](http://www.eeworld.com.cn/circuit/upload/366118de2d359b39c9c709fca68269f8/7d50d86ed2ff5af7f572d723b6e133e3.jpg)
Wireless data communication unit circuit
GSM communication module circuit design
The GSM communication module adopts SIEMENS' TC35I. TC35I is a special module specially designed by SIEMENS for GSM communication. It has voice, data, fax and point-to-point SMS functions. It works in the EGSM 900 and GSM 1800 frequency bands. It weighs only 10g and can operate normally within the range of 3.5~4.8V. The main instructions defined by AT Commands Interface Version 8.5 can be executed well, and there are more than 20 extended instructions.
The TC35I interface consists of 40-core cable. Among them, pins 1~5 are connected to the "+" terminal of the battery, pins 6~10 are connected to the "-" terminal of the battery, and pins 11~12 are the DC power input terminals, which can input 8~20V/500mA DC power. There is an automatic charging control circuit inside. The 15-pin IGT is for module startup control, and the 31-pin EMERGOFF is for shutdown control. They are both active at low level, and can also be turned on and off through commands. Pin 17 is the ringing output, pin 18 Rx is the serial data output, pin 19 TX is the serial data input, pin 32 is the working status indicator output, and pins 24~29 are connected to the SIM card. The interface circuit with the microprocessor is shown in Figure 4. The communication rate is 19.2kbps.
![Circuit design using TC35I wireless data transmission and GSM communication module](http://www.eeworld.com.cn/circuit/upload/366118de2d359b39c9c709fca68269f8/cf3672e985ad93b9e4afbf951b781df5.jpg)
Interface circuit between TC35I and microprocessor
All instructions for TC35I can be downloaded from the SIEMENS website. The vehicle-mounted user mobile payment system is composed of a low-cost AT89C4051 microcontroller with a working power supply of 3.3V. The base station is composed of a high-speed and high-performance 77E58-40 microcontroller to complete wireless data communication and identity authentication functions. CCD vehicle model recognition is completed by another independent processing unit.
- How about the boost converter TPS61299?
- What kind of circuit is a voltage regulator circuit?
- Miniature polarity reversal power supply using MAX1721
- Charging control circuit made by solar energy
- Adjustable regulated power supply with current limiting protection
- CNC regulated power supply production
- UC3842 Electric Vehicle Charger
- MIC4680 constant current charger
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- Switching power supply circuit composition and detailed explanation of each part (1)
- Power circuit a composed of intelligent thyristor modules
- Industrial product promotion and shopping guide DC power supply circuit
- Typical Reference Voltage and Power Supply Circuits
- Power circuit of LBO-522 dual trace oscilloscope
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- led drive power circuit
- Common power circuits and applications 08
- Common power circuits and applications 01
