A simple upconversion mixer circuit diagram
Source: InternetPublisher:赔钱虎 Keywords: AC power supply and other power circuits Updated: 2021/12/09
This article introduces a simple upconversion mixer circuit, which is implemented using a switched transconductance structure to eliminate the contribution of the switch to noise and reduce the noise figure of the mixer. At the same time, using the inductor-capacitor resonant network as the load can effectively increase the AC load impedance value, reduce the requirements for the mixer transconductance, and increase the transductal overdrive voltage, thereby achieving high linearity.
![A simple upconversion mixer circuit diagram](http://www.eeworld.com.cn/circuit/upload/7c326dc1b1f04345593d656ce816f84a/1c9bc32c2476d3d49fd5d058bf9f552c.jpg)
- Benefits of Wide Bandgap Technology for Power Converters
- Basic connection circuit of signal and power supply composed of ISOll3
- Detailed explanation of 5v charger circuit diagram
- Current/voltage conversion circuit using current converter
- Using CW34603 to form a circuit to change the polarity of the output power supply
- An ultra-low output voltage regulator
- Production of backup power supply for cordless phone
- Adjustable voltage regulated power supply circuit
- Circuit diagram explanation: simple switching power supply circuit diagram
- Detailed explanation of mobile phone charger circuit diagram
- Design of temperature detection circuit implemented by single chip microcomputer
- Determining the prerequisites for successful circuit board design
- Utilizing light sensing circuits to reduce photodiode bandwidth and noise effects
- LDC1000 working principle and circuit schematic diagram
- Valuables detection circuit design
- Those classic analog circuits worth collecting
- Single chip multi-microcomputer system sharing RAM circuit
- Single Supply Op Amp Applications
- Op amp clamp circuit
- 60Hz input notch filter circuit
