Low loss instrumentation amplifier
Source: InternetPublisher:柯南道尔 Keywords: Amplifiers power supplies and other power circuits Updated: 2020/11/12
![Low loss instrumentation amplifier](http://www.eeworld.com.cn/circuit/upload/6f674d3ca8b315a591a0d3957b1ce532/c6f1354f4962675018ffdb6d10497227.gif)
Instrumentation amplifiers generally require one or two 9V resistor batteries. Due to the serious current loss, these instruments need to be turned off when not in use. The working battery of the meter introduced here is two 1.5V flash batteries, and the power loss of the meter is very low, so there is no need for any on/off switch.
- Build a simple buck-boost regulator and test it on a breadboard
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Simple and practical LED lamp driving circuit
- Miniature polarity reversal power supply using MAX1721
- Constant current charger using light emitting diode as voltage regulator
- UC3842 Electric Vehicle Charger
- MIC4680 constant current charger
- Variable gain operational amplifier circuit diagram
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- Differential bridge amplifier circuit diagram
- Adjustable output voltage regulator circuit diagram
- Ultrasonic proximity sensor circuit
- A crystal controlled local oscillator circuit diagram
- OTL low frequency power amplifier circuit
