Diagram of the circuit principle of an electric fan
Source: InternetPublisher:王达业 Keywords: Power supply other power circuits Updated: 2021/09/20
Hello everyone, today I would like to share with you the circuit principle of the electric fan around us. Let’s explain it to you based on the circuit diagram.
![Diagram of the circuit principle of an electric fan](http://www.eeworld.com.cn/circuit/upload/22a92d7624c17a58339ef733bf248241/632c09e1d8ba7a0ac77d02c2702588a2.jpg)
Electric fan circuit diagram
As can be seen from the picture above, this circuit can be divided into three parts, the 220V AC power circuit on the far left, the swing circuit in the middle, and the fan circuit on the far right. The electric fan motor is a single-phase AC motor. It has two windings inside, one is called the running winding (also called the main winding), and the other is the starting winding (also called the auxiliary winding). The starting circuit is composed of split-phase capacitors, so that the main and auxiliary windings are spatially separated by 90° electrical angle. The speed regulating circuit is composed of a reactor speed regulating switch connected in series. By adjusting the size of the reactance, the voltage of the motor is changed to achieve speed regulation. After understanding this circuit diagram, it is enough to repair the electric fan.
- A very convenient small power supply circuit to share
- Build a simple buck-boost regulator and test it on a breadboard
- 220V Remote Load Monitor
- Fabrication of multi-cell lithium battery charging circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- ISO113 circuit that can reduce power consumption
- LM317 regulated power supply
- Adjustable voltage power socket
- Production of backup power supply for cordless phone
- Battery powered switching circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
