LTC2053 thermocouple amplification circuit diagram
Source: InternetPublisher:兰博 Keywords: Measurement power switch voltage regulator Updated: 2020/06/20
The amplifier LTC2053 amplifies the output mv model of the thermocouple. Since the LTC2053 works on the sampled input signal, the frequency of interest is generally lower than a few hundred Hz. In this way, adding a 0.1 fog capacitor C1 in the feedback circuit can speed up the response of the amplifier. . Capacitors C2 and C3 connected to the thermocouple input network help absorb radio frequency interference and suppress interference in the thermocouple probe.
Sampling interference occurs. Resistors R6~R9 connected in the thermocouple provide high impedance bias, which maximizes the interference immunity of the probe without voltage drop. Short thermocouples minimize common-mode signals and allow the probe node to be grounded. The 5.1V voltage regulator tube VD1 forms a power supply protection circuit, which prevents overvoltage of the power supply and reverse polarity of the 6V battery. R3 is a current limiting resistor. The working principle of a thermocouple is to generate a potential difference based on the temperature difference between the hot end and the cold end. Since the temperature of the cold end is often not 0°C during actual measurement, the thermocouple needs to be temperature compensated.
- Schematic diagram of car cigarette lighter to USB power port
- In-depth analysis of DC-AC converter inverter
- Driving circuit of switching power supply field effect tube
- Basic circuit description of adjustable voltage regulator LM317
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Transformerless AC-DC constant current LED driver circuit
- Switching power supply circuit composition and function introduction of each part
- Using CW34603 to form a circuit to change the polarity of the output power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- LM317T voltage regulation adjustable circuit diagram explanation
- Op Amp and Analog Switching Rohn Compensator
- Camera power supply circuit
- DVD switching power supply circuit schematic diagram
- Power supply step-down control circuit module design
- PNP and NPN transistor switching circuits
- Typical Reference Voltage and Power Supply Circuits
- EPSON PHOTO 830U printer power circuit
- Three-way DC-DC converter circuit
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- CF1 (CF2) DC power supply circuit
