A kind of non-inductive analog relay principle circuit
Source: InternetPublisher:拳制龙 Keywords: Power supply other power circuits Updated: 2020/10/29
Today I will introduce to you a non-inductive analog relay. Its circuit principle is shown in the figure below. In the figure, the 220V power supply supplies bias to Q4 and Q3 in turns in the positive and negative half cycles through the loads RL, R1, D1~D4, and ZD1; at the same time, it provides power to the photocoupler Q1 through R3, D5~D8. When the front-stage TTL circuit outputs a high-level signal, the photocoupler is turned on during the positive half cycle of the mains power, so a voltage drop occurs across R5, triggering the SCR to turn on, and the load RL is powered to work. The entire circuit functions like a relay, but does not generate reverse induced voltage, thus avoiding the possibility of the load being damaged by high back voltage breakdown. C1 and R6 are pulse absorption components, and R3 plays the role of current limiting.
In order to avoid the 90° phase between the voltage of the thyristor and the power supply of the photocoupler when RL is an inductive load, the power supply of the photocoupler in this circuit is taken from the anode of the SCR and not directly from the mains power supply.
![A kind of non-inductive analog relay principle circuit](http://www.eeworld.com.cn/circuit/upload/bf8c3a716e2b88f93e6a770d7495c9db/7e4928d8d2fd3a9b084d575d6c228188.jpg)
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- 220V Remote Load Monitor
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Step-down power supply for driving relays
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Boost drive circuit composed of RT8450
- A small and easy-to-make fast charger
- Adjustable voltage power socket
- USB power socket using the car battery
- Car Audio Power Supply
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
