A delayed pull-in relay circuit diagram
Source: InternetPublisher:三月小雨 Keywords: Power DC/DC Updated: 2021/12/08
If you want to obtain a long-term and easily adjustable delay circuit, the relay current should be controlled by a transistor, and an RC link should be connected to the base circuit, as shown in the figure. If the power supply voltage, capacitance C, current amplification coefficient β and the required pull-in power are all known, the appropriate relay coil resistance value and operating voltage value should be selected to make the delay time as large as possible. This time can be obtained by The time constant value is determined. As shown below:
![A delayed pull-in relay circuit diagram](http://www.eeworld.com.cn/circuit/upload/75ac04e004ce2bbd092ca26fb4b89404/372495716b6496f673b48ca112f73d96.jpg)
- How about the boost converter TPS61299?
- 220V Remote Load Monitor
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- What kind of circuit is a voltage regulator circuit?
- LED rechargeable flashlight circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- 3~15V 10A adjustable voltage regulated power supply
- MAX1811 Lithium Battery Charger Production
- Homemade Electric Bike Fast Charger
- Homemade home inverter circuit diagram
- DC output DC converter circuit
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Ten circuit designs for precision full-wave rectification
- A typical application circuit diagram of PS61040
- STR5412 power circuit
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit a composed of intelligent thyristor modules
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
