DC output DC converter circuit
Source: InternetPublisher:Lemontree Keywords: Power supply DC/DC voltage regulator Updated: 2020/03/17
A DC converter circuit that takes a single DC input and converts it into multiple parallel DC outputs.
![171115927.png](http://www.eeworld.com.cn/circuit/upload/1ae0362bbfc483734430527cde23d6d9/db2750adbda206278be8160df0d7e331.png)
Circuit description
This circuit uses a single DC input (nominally 12 volts) and converts it to four simultaneous output voltages of 9, 6, 5 and 1.5 volts. Common 78xx series voltage regulators provide output voltage control, providing 9, 6 and 5 Vdc outputs. The 1.5 volt power supply is derived using an LM317 voltage regulator. In order to reduce the electrical energy and thermal energy output from the 5 volt regulator the LM317 is fed. Calculation of the output of LM317: VO = 1.25 (1 + R1/R2) and R1 200 ohms (using 180 plus 22 ohms in series) This project is 1.5 volts. F2, 3,4,5 output fuse, at 500 mA (0.5). If the input power is full 500 mA then the DC input must be able to source at least 2 amps from each output. 1 lit LED shows the circuit is operating.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Build a simple buck-boost regulator and test it on a breadboard
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Driving circuit that controls LED brightness using PWM signal
- LED Driver ZD1680
- Detailed explanation of 5v charger circuit diagram
- Switching power supply circuit composition and function introduction of each part
- MIC4680 constant current charger
- MAX1811 Lithium Battery Charger Production
- Contact switch or proximity sensor circuit
- Op Amp and Analog Switching Rohn Compensator
- Instantaneous water heater automatic constant temperature experimental circuit diagram
- Broadband Frequency Multiplier Circuit
- A stepper motor and its driving principle circuit diagram
- Control circuit diagram of demagnetization switch using CD2-G type
- Three-way DC-DC converter circuit
- Commonly used power circuits in printers
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Warm current power supply circuit b
