Dual power supply tube power amplifier circuit
Source: InternetPublisher:JFET Keywords: Power supply other power circuits Updated: 2020/03/19
The characteristic of the figure below is that it uses dual power supplies. The negative grid voltage of the 6N5P is divided by R3 and R4 and then added to the grid of the power amplifier tube through R5. According to the requirements of different power tubes for negative grid voltage, different voltage division values can be taken. , this circuit is suitable for various power tubes. The ground terminal of the filament of the two tubes in the circuit should be connected to the lower end of their respective cathode resistors, that is, the ground terminal of the 6N5P filament should be connected to the lower end of R6, and the ground terminal of 6N2 should be connected to the lower end of R2 to reduce the distance between the cathode and the filament. potential difference between them. Therefore, the power transformer is required to have two filament windings. The filaments of the power stage and the front stage are powered separately. Note: Be sure to plug in the 6N2 tube before turning on the power. Otherwise, power cannot be applied.
- Analysis of the working principle of switching regulator
- How about the boost converter TPS61299?
- 220V Remote Load Monitor
- ISO113 circuit that can reduce power consumption
- Use pulse width modulation to get a precise output voltage
- The constant current source composed of two transistors can drive high power
- Switching power supply circuit composition and function introduction of each part
- A novel and practical DC low voltage stabilized power supply
- Power supply circuit that can reduce LM317 ripple
- UC3842 Electric Vehicle Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
