Light control switch circuit in incandescent lamp
Source: InternetPublisher:奥特man123 Keywords: AC power supply monitor power supply Updated: 2020/08/30
Under normal conditions, the alternating current forms a loop through the voltage dividing circuit composed of incandescent lamp, VD4~VD7 rectifier bridge, resistor R9 and the voltage stabilizing circuit composed of VD3 and C4. The loop current is less than 0.9mA, the power consumption is less than 0.2W, and the lighting does not light up. When the sound sensor receives the sound wave, the sound wave signal is converted into an electrical signal, which is amplified by IC1a and IC1b, and then passes through the coupling capacitor C1 to remove the interference signal generated by low-frequency vibration. When the ambient light is strong, the signal is bypassed by the photosensitive diode VD1 and is not output to the rear stage; when the ambient light is weak, VD1 is open circuit, and the acoustic signal output by the front stage is amplified by IC1c and 1C1d, and is composed of VD2, C2, and R4 The rectifier filter circuit rectifies the audio signal output by IC1d (which is quickly charged to C2 through VD2 in one direction) into a DC signal. At the same time, C2 and R4 also have a delay function, and the delay time is RC=22s. When the sound wave signal output by IC1d is a relatively short interference signal, the transition time from low to high level at the output terminal of C2 is shorter than the level transition time of the delay loop composed of R5 and C3. At this time, the output of C2 The signal cannot affect the change of C3 output level, and the interference signal is shielded; when the sound wave signal is normal, the level signal output by C2 passes through R5, C3, IC1f, R8, delays the connection of SCR, and the incandescent lamp lights up. Light control switch circuit in incandescent lamp:
![Light control switch circuit in incandescent lamp](http://www.eeworld.com.cn/circuit/upload/f91727a56d35ede22cfb222c48cd794d/ad9e293f09b297673bad735da108a895.jpg)
- Schematic diagram of car cigarette lighter to USB power port
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Recommended circuits for different power on times of LM4911
- Driving circuit that controls LED brightness using PWM signal
- Parallel DC regulated power supply circuit diagram
- Low cost and high performance LED constant current power supply
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Constant current charger using light emitting diode as voltage regulator
- A low-cost, high-reliability battery charger for electric vehicles
- Homemade home inverter circuit diagram
- Circuit using NCP1216 to drive LED
- Circuit diagram of a high-brightness and energy-saving LED lamp cup
- LED backlight driver module design circuit
- Three-phase phase loss alarm light circuit
- TLV3501 comparator circuit design: AC coupled single supply comparator
- Dual tone telephone dialing display circuit diagram
- Simple light-emitting display logic pen circuit
- Positive terminal buck/boost LED constant current drive circuit diagram
- Fully automatic multi-purpose intelligent lighting circuit design
- Dual adjustable power circuit
