Circuit diagram of a regulated power supply that outputs -5V DC voltage
Source: InternetPublisher:石榴姐 Keywords: power supply voltage stabilizer Updated: 2020/11/23
The 79XX series integrated voltage regulator is a commonly used three-terminal integrated voltage regulator with a fixed negative output voltage. Except that the input voltage and output voltage are both negative values, other parameters and features are the same as the 78XX series integrated voltage regulator. The three pins of the 79XX series integrated voltage regulator are: pin 1 is the ground terminal, pin 2 is the input terminal, and pin 3 is the output terminal.
The application circuit of the 79XX series integrated voltage regulator is also very simple. The figure below shows a regulated power supply circuit that outputs -5V DC voltage. The IC uses an integrated voltage regulator 7905. When the output current is large, a heat sink should be installed.
![Circuit diagram of a regulated power supply that outputs -5V DC voltage](http://www.eeworld.com.cn/circuit/upload/d7055b25a279d0f0a3d93d488574a61e/0611c45248fe9d8c09589010e1d1b75c.jpg)
- In-depth analysis of DC-AC converter inverter
- Basic circuit description of adjustable voltage regulator LM317
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- The constant current source composed of two transistors can drive high power
- Switching power supply circuit composition and function introduction of each part
- Adjustable regulated power supply with current limiting protection
- An ultra-low output voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- Car Audio Power Supply
- A low-cost, high-reliability battery charger for electric vehicles
- Design of adjustable DC stabilized power supply circuit module
- Output 12V-10A power supply circuit
- KGDS type single-phase low temperature iron plated power supply circuit
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Household emergency power circuit 02
- Common power circuits and applications 08
- ±5V, ±12V power circuit B
- 6.3V, 270V, 300V DC power supply circuit
- High quality power supply circuit schematic diagram
