An automatically adjusting temperature controller circuit
Source: InternetPublisher:石榴姐 Keywords: Power DC/DC Updated: 2021/12/24
This article introduces a fluid media temperature controller that uses the principles of thermal expansion and contraction of temperature-sensing fluids and the incompressibility of liquids to achieve automatic adjustment.
The thermostat physically deforms inside the switch according to the temperature change of the working environment, thereby producing some special effects, producing a series of automatic control components that conduct or disconnect actions, or the different working states of electronic components at different temperatures. The principle is to provide temperature data to the circuit for the circuit to collect temperature data.
![An automatically adjusting temperature controller circuit](http://www.eeworld.com.cn/circuit/upload/27cd60f2c68c932df976719c1451d753/9132e3450c10cf15ed1e42e5fb3ba4ba.jpg)
- Practical and convenient fax machine power supply control circuit
- Basic circuit description of adjustable voltage regulator LM317
- The constant current source composed of two transistors can drive high power
- Principles and precautions of active discharge circuit
- A novel and practical DC low voltage stabilized power supply
- Power supply circuit that can reduce LM317 ripple
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade Electric Bike Fast Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Importance of Voltage Supervisors and Output Topology Selection
- DC output DC converter circuit
- Clock switching circuit and its precautions
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit of STR5412
- Signal simulator circuit diagram
- Dual-purpose voice-activated switch circuit diagram
- Three-way DC-DC converter circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
