Instantaneous water heater automatic constant temperature experimental circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Power supply other power circuits Updated: 2020/08/30
I have been using the instantaneous water heater at home for many years, but every time I take a bath, I feel troubled. The water temperature control of the water heater is divided into 9 levels. The larger the number from 1 to 9, the higher the temperature. It should be easy to use. However, the water flow can also control the water temperature, and often causes the temperature to be out of control. For example, the water pressure decreases and the water volume becomes smaller. The heat cannot be taken away by the water immediately. The temperature (protection) switch inside the water heater will activate and you will be scalded. It is very uncomfortable to be tortured by cold water after a while.
In order to change this situation, I added a simple temperature control circuit, which can control the heating time of the original circuit, that is, the duty cycle. The effect is satisfactory, especially the temperature (protection) switch inside the water heater never operates again, which is very comfortable. .
The temperature sensor in the circuit uses an old-fashioned thermistor. Since the resistance is a bit small, a germanium diode is added for this purpose.
The main components used in the water heater circuit are: ULN2003AN, 7805/7812, BTA41600B, JQX-15F, HMS87C1202A, MOC3021.
![Instantaneous water heater automatic constant temperature experimental circuit diagram](http://www.eeworld.com.cn/circuit/upload/05963f1b9e79ea6c5d19af6ac3272721/2908fcfcf530972a72e2db707d48dc72.jpg)
- Build a simple buck-boost regulator and test it on a breadboard
- Schematic diagram of car cigarette lighter to USB power port
- Energy-saving motorcycle rectifier regulator
- Basic connection circuit of signal and power supply composed of ISOll3
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Voltage-current converter constructed with XTR110
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- Production of backup power supply for cordless phone
- LM317T voltage regulation adjustable circuit diagram explanation
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
