pulse width detector circuit
Source: InternetPublisher:柯南道尔 Keywords: Power supply other power circuits Updated: 2021/03/16
The 555 timer circuit shown in the figure will only produce an output when the trigger pulse is greater than the time constant of the monostable multivibrator (t=1.1RtCt). Q1 is usually closed. Pin 2 of the 555 timer then goes high. When the trigger pulse is on, the output at point C is very low. The positive trigger drives Q1 to turn on.
- Visible laser digital control modulation driver
- LED rechargeable flashlight circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Miniature polarity reversal power supply using MAX1721
- An ultra-low output voltage regulator
- Homemade low-power UPS
- LM317 regulated power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Detailed explanation of mobile phone charger circuit diagram
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
