A classic output short-circuit protection circuit
Source: InternetPublisher:走马观花 Keywords: Power supply other power circuits Updated: 2023/12/12
Power on: The voltage at both ends of C2 cannot change suddenly. The base voltage of Q2 starts to decrease from VCC until it reaches the point where Q2 can be turned on (BE junction voltage drop is 0.7V). This time is about 0.12mS. But at the same time, Q1 is also preventing Q2 from turning on. The time for Q1 to turn on is approximately: 5.87mS, which means that Q2 will not turn on until 5.87mS, but at the same time, C3 is preventing Q3 from turning on. The blocking time is 0.17mS.
Q3 turns on after 0.17MS of power-on, the load is powered, and the C-pole voltage of Q3 reaches about 13.3, forcing Q2 to cut off. This shows that Q1 can be removed.
When short-circuited, the C pole of Q3 is pulled low, Q2 is turned on, forming a self-locking force, forcing Q3 to cut off, and there is no voltage to the load behind Q3. At this time, it does not matter whether there is a load or not, so there will be no output even if the load is removed. If you want to restore the output after removing the load, you can connect a resistor to the CE junction of Q3, about 1K.
- 0-30V Mini Desktop Power Supply
- Vehicle-mounted 12V to 50V DC converter
- Lithium-ion battery charger
- 500W MOSFET power inverter 12V to 110V/220V
- Lithium polymer battery overvoltage protection
- 10A 1-30V Adjustable Power Supply Based on LM317
- USB Lithium Polymer Battery Charger
- Gate drive transformers vs. high-side and low-side drivers: Where is power supply design headed?
- 3 Ways to Design a Low Quiescent Current (Iq) Automotive Reverse Battery Protection System
- Power Converter Topology Component Selection for High Input Voltage Applications
- Teach you a thyristor dimming LED drive power circuit design
- Analyze the working principle, advantages and disadvantages of the SPI interface
- Isolation technology that maximizes power efficiency and minimizes radiation
- A design plan for a serial communication interface circuit
- A brief discussion on the circuit diagram of electrical control
- Fully automatic multi-purpose intelligent lighting circuit design
- What’s so magical about the main circuit inside the inverter?
- Unit circuit of voltage and current control loop
- ×10 operational amplifier L161
- IC4069 simple infrared remote control switch circuit diagram
京公网安备 11010802033920号
