Capacitive sensor system circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: AC power supply and other power circuits Updated: 2021/05/15
This circuit diagram shows the electric field configuration of a capacitive proximity sensor in the form of a capacitive reflector. It consists of a sensing electrode driven by an AC voltage, creating an electric field near the electrode. Material entering this electric field will be induced by the magnetic field on the resistor between the sensing electrode and electrical ground.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Practical and convenient fax machine power supply control circuit
- Step-down power supply for driving relays
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Power supply circuit that can reduce LM317 ripple
- Converting a lithium battery charging board into a constant voltage and current charger
- Production of backup power supply for cordless phone
- Detailed explanation of mobile phone charger circuit diagram
- Design of temperature detection circuit implemented by single chip microcomputer
- Determining the prerequisites for successful circuit board design
- Utilizing light sensing circuits to reduce photodiode bandwidth and noise effects
- LDC1000 working principle and circuit schematic diagram
- Valuables detection circuit design
- Those classic analog circuits worth collecting
- Single chip multi-microcomputer system sharing RAM circuit
- Single Supply Op Amp Applications
- Op amp clamp circuit
- 60Hz input notch filter circuit
