High and low temperature two-way thermometer circuit diagram
Source: InternetPublisher:柯南道尔 Keywords: Power supply other power circuits Updated: 2020/02/15
The picture shows the circuit diagram of a high and low temperature two-way thermometer. The circuit is divided into two parts, consisting of A, B, R4, and C1 to form the upper limit alarm function. C, D, R5, and C2 constitute the lower limit alarm function.
RP1 and RP2 set two alarm points, the upper limit and the lower limit respectively, so that the A and C input terminals are both high level and the output is low level to stop the oscillators. When the temperature is too high, the resistance of the thermistor R1 decreases, causing A to output a high level, B to vibrate, and the piezoelectric ceramic piece YD to emit a high-pitched buzzer. At the same time, the light-emitting diode LED1 lights up, indicating that the temperature is too high. When the temperature is too low, the resistance of the thermistor R2 increases so that C outputs a high level, D starts to vibrate, and the piezoelectric sheet YD emits a low-pitched buzzer. The light-emitting diode LED2 lights up, indicating that the temperature is too low.
If a photoresistor is used instead of a thermistor, it can be used as a light intensity alarm. The other input end of the Schmitt trigger can also be used for dual-function bidirectional alarm of light and temperature. The control signal is derived from the LED to control light filling and humidification (such as ultrasonic humidifier) to form an automatic light filling and constant humidity controller.
Since the static power consumption of the CMOS circuit is extremely small and the current is only at the microampere level, the power consumption in the static state is mainly on RP1, RP2 and the thermistor. If a special temperature measuring resistor with a resistance of more than 100 kΩ can be used, and RP1 and RP2 are increased accordingly according to the proportion in the figure, the power consumption in static state can be controlled to be very small, which is extremely beneficial to extending the service life of the battery.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- 220V Remote Load Monitor
- Step-down power supply for driving relays
- What kind of circuit is a voltage regulator circuit?
- Transformerless AC-DC constant current LED driver circuit
- How to use SBR to improve power conversion efficiency
- Constant current charger using light emitting diode as voltage regulator
- Mc34063 MP3 Switching Charger
- Practical constant current charger-----Constant current charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
