Zero-crossing trigger circuit diagram based on thyristor
Source: InternetPublisher:走马观花 Keywords: AC power supply AC/DC Updated: 2021/08/06
The zero-crossing synchronization pulse is a pulse at the zero-crossing moment of the 50Hz AC voltage, which can trigger the conduction of the thyristor when the AC voltage sine wave crosses zero. The zero-crossing synchronization pulse is generated by the zero-crossing trigger circuit. A more detailed circuit diagram is shown in the figure. In this figure, the voltage comparator LM311 is used to convert the 50Hz sinusoidal AC voltage into a square wave. The positive edge and negative edge of the square wave are used as the input trigger signals of the two monostable triggers respectively. After the two narrow pulses output by the monostable trigger are mixed by the diode or gate, the process corresponding to the AC 220V mains power can be obtained. Zero sync pulse. On the one hand, this pulse is added to the temperature control circuit as a trigger synchronization pulse for the thyristor, and on the other hand, it is also added to the T0 and T1 terminals of the 8031 as a counting pulse.
![Zero-crossing trigger circuit diagram based on thyristor](http://www.eeworld.com.cn/circuit/upload/6e12dc634d8c84dc345854fb7e79ea83/f4b314aa2d3d0e19dee4108aaa05b9c6.gif)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Build a simple buck-boost regulator and test it on a breadboard
- Benefits of Wide Bandgap Technology for Power Converters
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Transformerless AC-DC constant current LED driver circuit
- LNK304 non-isolated LED light string driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A simple positive and negative power supply circuit
- UC3842 Electric Vehicle Charger
- Mc34063 MP3 Switching Charger
- Principle of single live wire power taking circuit
- Light control switch circuit in incandescent lamp
- A RKC XTE-7000 temperature controller circuit diagram
- 60Hz input notch filter circuit
- Zero-crossing trigger circuit diagram based on thyristor
- Interface circuit diagram for controlling AC load
- Simple 1-12V constant current charging circuit diagram
- Laser power circuit
- Commonly used power circuits in printers
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
