How to ensure that the power supply works for a long time—PA power analyzer
Source: InternetPublisher:三月小雨 Keywords: Charger controller power supply pa power analyzer Updated: 2021/12/02
The PA power analyzer can accurately measure the output voltage, current, power, harmonics and conversion efficiency of the power supply. Zhiyuan's PA5000H power analyzer has 0.05% power measurement accuracy, 5MHz bandwidth and rich harmonic measurement functions and is widely used R&D and testing of power supply products.
Power analyzer—electrical parameter testing
The power analyzer focuses on steady-state testing. The power analyzer can test AC input and DC output at the same time, conduct synchronous analysis of overall energy efficiency and electrical parameters, and test input and output voltage, current, test voltage, current effective value, power factor, Efficiency, harmonics, etc., as shown in Figure 1.
Figure 1 Electrical parameter test
Power analyzer—efficiency and power factor testing
The power analyzer tests the AC input power and DC output power, and sets the electronic load from no load to full load. Using the XY display mode of the power analyzer, you can directly test the efficiency and power factor curves from no load to full load.
Figure 2 Efficiency curve graph
Figure 3 Power factor curve graph
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- A simple positive and negative power supply circuit
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- UC3842 Electric Vehicle Charger
- Mc34063 MP3 Switching Charger
- Practical constant current charger-----Constant current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Detailed explanation of mobile phone charger circuit diagram
- TI TCAN4550 system basic chip analysis
- A typical application circuit diagram of PS61040
- Cat Meow Simulator Circuit 2
- Charger and adapter power supply circuit design
- Voltage detection relay for battery pack charger
- Circuit diagram of using microprocessor SM5K5 to control the charger
- Safe and practical charger
- Fully automatic two-stage constant current charger
- Charger with constant current charging hotel function
- Multipurpose constant current charger
