Battery fast charging control integrated circuit design
Source: InternetPublisher:柯南道尔 Keywords: Power battery circuit Updated: 2020/04/19
Circuit principle: The circuit provides +5V power supply voltage by a transformer, diode and voltage regulator IC7805. The battery voltage is divided by resistors R5 and R6 and then sent to the BAT end of the chip to provide a sampling voltage. The resistance of the resistor voltage divider network input to the BAT terminal should not be less than 200kΩ. When the TM terminal is grounded, the corresponding fast charge charging rate is 1C and the fast charge replenishment time is 80 minutes.
![Battery fast charging control integrated circuit design](http://www.eeworld.com.cn/circuit/upload/78a01d79c152af1feea22947b8f1726c/bbc77f7fb31945956d6ec767c670f230.jpg)
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Simple and practical LED lamp driving circuit
- How to use SBR to improve power conversion efficiency
- Boost drive circuit composed of RT8450
- LM317 regulated power supply
- Car power 1.5V-12V six-speed converter
- Design of electric vehicle charger
- MIC4680 constant current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- LM317T voltage regulation adjustable circuit diagram explanation
- CMOS touch circuit
- Nickel cadmium battery remote control
- Portable device charging power circuit design
- Solar power circuit
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Remote control TV doorbell power circuit
- Head amplifier dedicated power supply circuit
- Neon light high voltage power supply circuit
- Common power circuits and applications 06
