Multi-channel signal generator circuit composed of upc1651
Source: InternetPublisher:狂妄火龙果 Keywords: Power supply other power circuits Updated: 2021/12/04
This article introduces a multi-channel signal generator circuit composed of upc1651. As shown in the figure, IC1 and C1 in the figure form a low-frequency oscillator of about 400HZ; IC2 and C3 form a high-frequency oscillator of about 37MHZ; the low-frequency signal output by C2 modulates the high-frequency signal. C4 and the antenna constitute the transmitting system. The harmonics of the high-frequency oscillator can be received on the third channel of the TV (or other channels) and display black and white bar signals. The output signals at point A and point B are used as detection signal sources for low frequency and image channels respectively. Replacing C3 with a quartz crystal can stabilize the oscillation frequency, as shown in the dotted line in the figure. If you use a pair of binding posts or sockets to connect C3, replace C3 with crystals respectively; select the frequency as 465KHZ, 10.7KHZ, 6.5KHZ, 4.43MHZ, 37MHZ, you can use it as an intermediate frequency signal source for radio recorders and televisions.
![Multi-channel signal generator circuit composed of upc1651](http://www.eeworld.com.cn/circuit/upload/306dcc5ec52e6d61ac393cdb8d008804/9895e7d2a8e62120d3157c143e226df2.jpg)
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How about the boost converter TPS61299?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Step-down power supply for driving relays
- What kind of circuit is a voltage regulator circuit?
- ISO113 circuit that can reduce power consumption
- LED Driver ZD1680
- Parallel DC regulated power supply circuit diagram
- The production of adjustable voltage-stabilized power supply composed of LM317
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
