MEMS strobe driver circuit diagram
Source: InternetPublisher:刘德华河北分华 Keywords: LED MEMS driver circuit diagram Updated: 2021/08/25
According to the principle of stroboscopic imaging, in order to collect clear images of MEMS devices when they move at high speed, this article uses EL6249C as the driver chip to drive the high-brightness laser diode to emit light, and uses a function generator to generate a narrow pulse signal with the same frequency as the MEMS movement frequency. Use it as the control signal of EL6249C, and then set the appropriate external resistor to make the EL6249C output the appropriate current to drive the LED to emit the required strobe light. The picture shows the schematic diagram of the strobe lighting circuit designed by the author.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Recommended circuits for different power on times of LM4911
- The constant current source composed of two transistors can drive high power
- LNK304 non-isolated LED light string driver circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Power supply circuit that can reduce LM317 ripple
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- MIC4680 constant current charger
- Battery powered switching circuit diagram
- What sensors does the phone have?
- LED backlight driver module design circuit
- Optocoupler isolation circuit with PNP transistor current amplification
- Three-phase phase loss alarm light circuit
- Five-digit LED level indication driver integrated circuit typical circuit
- 3W high power LED drive circuit diagram
- Level display circuit diagram composed of LED level meter driver integrated circuit
- 5-point LED driver circuit diagram of HA7666P/TA7667P
- Positive terminal buck/boost LED constant current drive circuit diagram
- Fire emergency light circuit
