Oscilloscope converter provides four channel display
Source: InternetPublisher:3228 Keywords: power display power supply Updated: 2021/06/21
The monolithic quad operational amplifier provides a low-cost way to enhance the display performance of a standard oscilloscope. The binary input drives the integrated circuit operational amplifier; a dual flip-flop divides the range of the gate output to obtain the channel select signal. All channels have centering zero offset voltage control. This circuit operates at 5MHz.
- Benefits of Wide Bandgap Technology for Power Converters
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Simple and practical LED lamp driving circuit
- LED rechargeable flashlight circuit diagram
- Principles and precautions of active discharge circuit
- USB power socket using the car battery
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- MAX1811 Lithium Battery Charger Production
- Homemade home inverter circuit diagram
- Battery powered switching circuit diagram
- LT3755 driver LED application circuit diagram
- Driving circuit diagram of a low-power LED bulb
- LED backlight driver module design circuit
- LED light column drive circuit
- A design method for electronic mosquito killing circuit
- Dual tone telephone dialing display circuit diagram
- Portable device charging power circuit design
- Laser power circuit
- Commonly used power circuits in printers
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
