Microcontroller controlled flash circuit
Source: InternetPublisher:三岁就很酷 Keywords: Diodes power supplies and other power circuits Updated: 2021/02/06
![Microcontroller controlled flash circuit](http://www.eeworld.com.cn/circuit/upload/49626d75b82ca81f8b2b72ed7ddf0c5b/89a88dabec185f350b51b327fe8145df.jpg)
This circuit can light up two lights in a cycle. This circuit is an astable multivibrator composed of a transistor (NPN9014, DC amplification factor should be >200), a red light-emitting diode and R and C components, and is powered by a 6V DC power supply. Execute the microcontroller programming process as shown in the figure, and you can see the two tubes flashing alternately.
- The basic principles of power supply design. What are the key components of a power supply?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to Make a Soft Latch Circuit
- Practical and convenient fax machine power supply control circuit
- Introduction and principle analysis of switching regulated power supply
- What kind of circuit is a voltage regulator circuit?
- Constant current LED lamp driver circuit with soft start and anti-shock
- Constant current charger using light emitting diode as voltage regulator
- UC3842 Electric Vehicle Charger
- Car Audio Power Supply
- Noise box circuit (1)
- Analysis of various power supply filter circuits
- Rectifier spike absorption circuit
- Acousto-optic digital level detector circuit diagram
- Object presence and displacement detection circuit
- Mobile phone shielding circuit that can be used as a charger
- PLC input and output wiring a
- Internal structure of MC1411 series Darlington current driverc
- Diode spark suppression circuit b
- Fast response circuit b when controlled by transistor
