Variable pulse width circuit
Source: InternetPublisher:念念Brown Keywords: Power supply other power circuits Updated: 2020/09/22
R1 and C2 together provide a wide range of pulse widths from the Motorola MC851P mono line. The rise and fall times of the supplementary output pulses are greater than 100μs. As long as four conversion capacitors are used in conjunction with R1, the pulse width can vary within the maximum range of 4.5ms and the minimum range of 4.5μs.
- In-depth analysis of DC-AC converter inverter
- Basic circuit description of adjustable voltage regulator LM317
- Simple and practical LED lamp driving circuit
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- An ultra-low output voltage regulator
- Car power 1.5V-12V six-speed converter
- Mc34063 MP3 Switching Charger
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
