Transistor based counting circuit diagram
Source: InternetPublisher:toothache Keywords: Power supply other power circuits Updated: 2020/10/02
![Transistor based counting circuit diagram](http://www.eeworld.com.cn/circuit/upload/2505df91103a1d0deb40e7f32a92026e/254ff638449c474f2f388867960424f2.jpg)
The above picture can be used for detecting and counting equipment such as paper machines. When the magnet sweeps across L with the rotation of the drum, an electric potential (i.e., a signal) is induced in L, VTi is turned on, VT2 is turned off, and relay KA loses power and is released. When the working line speed of this switch is 0. 48-9.9m/s, the response distance is 15~55mm.
Among them, the inductor L is wound with 6500 turns of enameled wire with a diameter of 0.06mm on the permanent magnet. The permanent magnet is a paper end positioning magnet (ferrite) adsorbed on the side of the paper drum.
- How about the boost converter TPS61299?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Energy-saving motorcycle rectifier regulator
- Driving circuit that controls LED brightness using PWM signal
- Detailed explanation of 5v charger circuit diagram
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
