Driving circuit diagram of a low-power LED bulb
Source: InternetPublisher:子丑寅卯 Keywords: power display power supply Updated: 2021/03/29
A general LED driver requires two LED current feedback and sometimes even uses a photocoupler to transmit the signal through an insulator to provide accurate and continuous current. For low-power LED bulbs, there is not enough space to add so many devices. . In order to solve these problems, this article introduces a low-power LED light bulb drive circuit. As shown in the figure below, this circuit uses STMicro's HVLED805. The LED driving power is less than 5W and the accuracy is +-5%. One device can solve the above problems and maintain stable output current CC and output voltage CV while also maintaining stable output current CC and output voltage CV. It has over-voltage protection to ensure the safety of the bulb.
![Driving circuit diagram of a low-power LED bulb](http://www.eeworld.com.cn/circuit/upload/b0d062c32e6387e16ac11c6253fabfcc/756882eda2a52e56c539ff266269ee49.jpg)
- Build a simple buck-boost regulator and test it on a breadboard
- In-depth analysis of DC-AC converter inverter
- Using Lead-acid Battery as Power Source for Walkman
- Practical and convenient fax machine power supply control circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Simple and practical LED lamp driving circuit
- Current/voltage conversion circuit using current converter
- 3~15V 10A adjustable voltage regulated power supply
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- LT3755 driver LED application circuit diagram
- Driving circuit diagram of a low-power LED bulb
- LED backlight driver module design circuit
- LED light column drive circuit
- A design method for electronic mosquito killing circuit
- Dual tone telephone dialing display circuit diagram
- Portable device charging power circuit design
- Laser power circuit
- Commonly used power circuits in printers
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
