Motor electronic speed regulation circuit
Source: InternetPublisher:super_star Keywords: Power supply other power circuits Updated: 2020/06/22
![Motor electronic speed regulation circuit](http://www.eeworld.com.cn/circuit/upload/866a53397965c5cc3f30b82ced7beb56/1e88101cfde94a704932b14172584613.jpg)
This circuit is simple and easy to make, and can be used to control the speed of small single-phase AC motors.
After the 220V AC voltage is stepped down by C3, rectified by VD3, filtered by C1 and stabilized by VS, it provides +12V DC working voltage for the IC. After the ultra-low frequency oscillator is powered on, it outputs an ultra-low frequency pulse signal with a frequency of about 1Hz from pin 3 of the IC. This pulse signal is added to the control end (positive end) of the solid-state relay KN, and the VTH is controlled by controlling the on and off of KN (when the pulse signal is a positive pulse, KN is on; when the pulse signal is a negative pulse, KN is off) conduction angle.
Adjusting the resistance of RP can change the duty cycle of the IC's pin 3 output pulse signal. The greater the duty cycle of the pulse signal, the longer the conduction time of VTH per unit time, the higher the operating voltage of the motor M and the faster the operating speed.
- Sharing layout and tips for multi-rail power supply design
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- ISO113 circuit that can reduce power consumption
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Power supply circuit that can reduce LM317 ripple
- CNC regulated power supply production
- UC3842 Electric Vehicle Charger
- MAX1811 Lithium Battery Charger Production
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
