Microcontroller control circuit
Source: InternetPublisher:通通 Keywords: power communication power supply communication Updated: 2020/11/27
![Microcontroller control circuit](http://www.eeworld.com.cn/circuit/upload/1af9895e10be39934345912e48078b5f/9b59cb618c202c84441ad87768f4f8fd.jpg)
Its main function is to complete the detection of the instantaneous value and peak value of overvoltage, the detection of the number of overvoltages, the detection of power supply output voltage and current, and display the size of each detection value through keyboard operation; at the same time, through the MAX485 interface and the host The machine realizes communication, and when there is overvoltage, the control circuit starts each power supply to protect the power supply itself.
- How to Make a Soft Latch Circuit
- Step-down power supply for driving relays
- Parallel DC regulated power supply circuit diagram
- Current/voltage conversion circuit using current converter
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- Homemade Electric Bike Fast Charger
- DC 12V to AC 100V inverter power supply circuit design
- Power circuit of LBO-522 dual trace oscilloscope
- Timing switch AC power circuit
- Household emergency power circuit
- Antenna amplifier synchronous power supply circuit
- Music power circuit
- Wide input 350mA LED driver circuit based on NCL30000
- Common power circuits and applications 05
- DC-DC conversion power supply circuit
- Small power UPS power circuit and production
