40W AC-DC LED driver solution based on iW3620 - power supply circuit - circuit diagram
Source: InternetPublisher:通通 Updated: 2021/07/09
iW3620 is a high-performance AC/DC offline LED driver. The device operates in quasi-resonant mode under high load conditions to obtain high efficiency and various built-in protection features to reduce EMI. The operating frequency is up to 130kHz, and the universal input voltage is 85 Vac to 264 Vac, can drive 40W LED lighting. This article introduces the main features and typical application circuits of iW3620.
iW3620: Digital PWM Constant Current Controller for AC/DC LED Driver
The iW3620 is a high performance AC/DC offline LED driver which uses digital control technology to build peak current mode PWM flyback power supplies. The device operates in quasi-resonant mode at heavy load to provide high efficiency along with a number of key built-in protection features while minimizing the external component count, simplifying EMI design and lowering the total bill of material cost. The iW3620 removes the need for secondary feedback circuitry while achieving excellent line and load regulation. It also eliminates the need for loop compensation components while maintaining stability over all operating conditions. Pulse-by-pulse waveform analysis allows for a loop response that is much faster than traditional solutions, resulting in improved dynamic load response. The built-in current limit function enables optimized transformer design in universal off-line applications over a wide input voltage range.
iW3620 main features:
Primary-side feedback eliminates opto-isolators and simplifies design
Quasi-resonant operation for highest overall efficiency and low EMI
Up to 130 kHz switching frequency enables small size
Very tight LED constant current regulation
Built-in output constant-current control with primary-side feedback for LED driver.
Low start-up current (10 μA typical)
Built-in soft start
Built-in short circuit protection and output overvoltage protection
Current sense resistor short protection
Over-temperature Protection
Open circuit protection
Universal input range from 85 Vac to 264 Vac
Single-fault protection
Small input bulk capacitor
Long MTBF
High efficiency
iW3620 Application:
Solid State LED lighting for incandescent, halogen, and fluorescent tube replacementFigure
1 Typical application circuit of iW3620
- 1.2-36V 5A Adjustable Power Supply (Based on LM317)
- 0-28V 20A Adjustable Power Supply (Based on LM317 and 2N3055)
- Automatic battery charger
- Solar charger for USB devices
- Simple lithium-ion/lithium polymer battery charger
- Charging monitor for 12V lead-acid batteries
- LM317 constant current source circuit design
- Charge-coupled bidirectional power MOSFET relay
- How to Determine Bandwidth from Transient Response Measurements
- Shaver power circuit
- DC 12V to AC 100V inverter power supply circuit design
- EPSON PHOTO 830U printer power circuit
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Transistor stabilized current power supply circuit 2
- Super Class A power amplifier power circuit
- audio power circuit
- Music power circuit
- Power circuit for home appliance repair
- 5V, 7.5V, 48V power circuit
- High quality power supply circuit schematic diagram
京公网安备 11010802033920号
