A stepper motor and its driving principle circuit diagram
Source: InternetPublisher:JFET Keywords: Power supply power supply and other power supply circuits Updated: 2020/05/08
Stepper motor is an open-loop control element stepper motor device that converts electrical pulse signals into angular displacement or linear displacement. Under non-overload conditions, the motor's speed and stopping position only depend on the frequency and number of pulses of the pulse signal, and are not affected by load changes. When the stepper driver receives a pulse signal, it drives the stepper motor according to the The set direction rotates at a fixed angle, called "step angle", and its rotation runs step by step at a fixed angle.
Stepper motor is one of the most commonly used control components in industrial control and instrumentation. It has the characteristic that the input pulse is proportional to the rotation of the motor shaft. It is widely used in intelligent robots, floppy disk drives, and data machine tools. Microcomputer control of stepper motors is most suitable. The system is designed to use the 20BY-0 model stepper motor, which is suitable for +5V DC power supply, the step angle is 18 degrees, and the motor coil is composed of four phases. The figure below shows a stepper motor and its driving principle circuit diagram.
![A stepper motor and its driving principle circuit diagram](http://www.eeworld.com.cn/circuit/upload/60ed1d9f807102346a78a304fe4a6dc6/b7a5aeb7bc2108d2a47e0d175d22ba8f.jpg)
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Practical and convenient fax machine power supply control circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- Op amp power supply decoupling bypass measures
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED Driver ZD1680
- Parallel DC regulated power supply circuit diagram
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- A low-cost, high-reliability battery charger for electric vehicles
- How to improve the performance of car power supplies
- As the leader in 65W power supplies, XPG CR650 power supply has been launched
- Did you know about a new power supply that provides more usable power?
- Power transformer use
- The reason why the power supply should be set to +3.3V
- Application circuit diagram of IGBT in CO2 gas shielded welding power source
- Automatically set timer
- Power circuit b composed of intelligent thyristor modules
- Pulse signal hypnotic circuit
- Broadband practical amplifier consisting of two stages of common emitter amplifier
