Broadband practical amplifier consisting of two stages of common emitter amplifier
Source: InternetPublisher:三月小雨 Keywords: Amplifier common emitter power supply filter Updated: 2021/12/06
Shown is a practical broadband amplifier consisting of a two-stage common-emitter amplifier . Input, output and inter-electrode coupling all use capacitance
. C4 and cs are emitter decoupling capacitors to eliminate AC negative feedback and enhance the ability of AC signal amplification.
The inductor (10 yH) connected to the -15V power supply and It6, C3, Rii, Island, C2, etc. are all filters used to filter out ripples in the power supply .
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Simple Wired Spy Bug Circuit Built Based on IC741
- Basic characteristics/working principles and application circuits of tunnel diodes
- Build a musical fountain using Arduino and sound sensor
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- An example of proportional integral circuit diagram
- Homemade air conditioner outdoor unit shutdown indicator
- Detection circuit diagram of AC side voltage Us based on SG3525
- ×10 operational amplifier L161
- volumeter
- Intrinsically protected safety op amp
- Basic Op Amp Differential Amplifier
- An ultra-high-precision level conversion circuit diagram
- Multistage amplifier circuit fault analysis
- non-diode rectifier
- Video driver schematic
- An FM transmitter overvoltage protection circuit diagram
