A single-section transistor performance test circuit
Source: InternetPublisher:失踪的猫 Keywords: Power supply other power circuits Updated: 2021/03/27
This article introduces a single-section transistor performance test circuit diagram. As shown in the figure below, the single-junction transistor VBT under test (assumed: BT33), R3, and C2 form a relaxation oscillator. When VBT is on, the transistor VT1 obtains the bias current through the bias resistor R2 (at this time, S1 is open and S2 is closed), and the light-emitting diode H1 emits light.
Among them, the 10V power supply charges C2 through R3 via VD2. Voltmeter V can measure that the voltage across C2 will continue to rise as time goes by. When the potential at E reaches the peak voltage of VBT, E~B1 of VBT will automatically conduct, and the voltage on capacitor C1 will pass through E~B1. Discharge causes the emitter junction of transistor VT1 to be reverse-biased and cut off, and H1 goes out. If the single-junction transistor VBT under test is good, the capacitor C1 will charge and discharge repeatedly, and H1 will flash alternately between light and dark. If H1 is always on, you can swap the B1 and B2 pins of the VBT for testing (this will also make it easier to correctly distinguish the Bl and B2 pins), otherwise the single-section transistor is a bad tube.
- Build a simple buck-boost regulator and test it on a breadboard
- Schematic diagram of car cigarette lighter to USB power port
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- The constant current source composed of two transistors can drive high power
- Switching power supply circuit composition and function introduction of each part
- Principles and precautions of active discharge circuit
- Integrated regulated power supply with continuously adjustable output voltage
- Circuit diagram explanation: simple switching power supply circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
