Do you know about lithium-ion battery charging IC equipped with current path function?
Source: InternetPublisher:MartinFowler Keywords: charging ic current path lithium ion Updated: 2021/04/29
What is a lithium-ion battery charging IC equipped with a current path function? What does it do? Torex Semiconductor Co., Ltd. (Managing Director, Chuo-ku, Tokyo, Japan: Koji Shibamiya; Second Tokyo Stock Exchange: 6616) has developed Current path function, charging IC for 1-cell lithium ion/polymer secondary battery (hereinafter referred to as lithium battery) [XC6806 series product].
The [XC6806 series products] developed by Torex this time are equipped with a current path function that can control the current for charging the battery and providing the system to an exact value. Compared with conventional products, the voltage at which charging is completed can be set within a wider range, and it can also be adapted to a variety of lithium batteries (charging voltage range: 3.5V to 4.45V). In addition, it is equipped with a shutdown function that completely stops the power supply from the battery to the machine. Because the battery leakage current can be suppressed to 100nA when the device is not in use, low-current consumption devices powered by small batteries can be used for a longer period of time.
It adopts USP-10B (2.9x2.6xh0.6mm) and LGA-10B01 (2.5 x 1.6 x h0.4mm) package components that are small and have excellent heat dissipation properties. You can choose the package according to the application.
Torex will continue to rapidly develop products based on market demand and continue to contribute to the realization of a prosperous society.
[Features of XC6806 series products]
・ Equipped with a current path function that can control charging current and system current
・Supports voltage of 3.5V~4.45V when charging is completed
・ Reduce battery leakage current to 100nA
・ Equipped with a shutdown function that completely stops power supply from the battery to the device. The above is the analysis of lithium-ion battery charging IC equipped with current path function. Hope it helps everyone.
- Build a simple buck-boost regulator and test it on a breadboard
- ISO113 circuit that can reduce power consumption
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- Homemade low-power UPS
- LM317 regulated power supply
- Adjustable voltage power socket
- Design of electric vehicle charger
- Converting a lithium battery charging board into a constant voltage and current charger
- Do you know about lithium-ion battery charging IC equipped with current path function?
- Portable device charging power circuit design
- Timing switch AC power circuit
- Diamond differential input power amplifier power circuit
- Household emergency power circuit 02
- Practical neon light power circuit
- Common power circuits and applications 09
- Common power circuits and applications 03
- Nine-speed adjustable DC power circuit
- ±5V, ±12V power circuit B
