How to make a constant current source using an op amp circuit
Source: InternetPublisher:黄土马家 Keywords: Constant current source analog circuit operational amplifier circuit Updated: 2021/11/16
1. Basic principles:
The principle of making a constant current source with an op amp is the addition and subtraction circuit of the op amp.
The circuit needs a reference power supply and a sampling resistor to determine the size of the output current. The potentials at both ends of the sampling resistor are compared and the sampling output is controlled to ensure that the voltage on the sampling resistor remains constant, thereby ensuring the constant output current.
2. Basic circuit:
The figure below is a typical constant current source circuit, the reference power supply Vref, and the sampling resistor RS.
3. Circuit analysis:
It can be seen that it is actually an adding circuit: its output Vo is the result of the superposition of two inputs Vref and Vo'.
V01=(Vref/2)*2=Vref
Vo2=(Vo'/2)*2=Vo'
Vo=Vo1+Vo2=Vref+Vo'
Then there are:
Vo-Vo'=Vref
Sampling the current in resistor RS:
I=(Vo-Vo')/RS=Vref/RS
If the current taken is very small, it satisfies:
IR<
In the actual circuit, as long as R>>RS is satisfied, IR<
Then there are:
Io≈I=Vref/RS
Therefore, the output current only depends on the reference voltage Vref and the sampling resistor RS, and has nothing to do with the output load.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- How to identify common mode interference? Methods to eliminate common mode interference
- Types and structures/characteristics/functions/implementations of smart sensors
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Working principle and truth table of JK flip-flop
- How to build a triangle wave generator using an op amp and discrete components
- How to install the accelerometer
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Simple LED advertising light circuit
- FL52C4 induction electronic greeter
- Do you know the difference between analog circuits and digital circuits?
- Direct coupling amplifier circuit circuit diagram
- One of three signal switches, multi-way switch CD4027 multi-way switch
- Several practical circuit resistor-capacitor voltage reduction principles
- Typical Schmitt trigger circuit diagram
- Six common constant current source circuit diagrams and analysis
- AN7177 power amplifier circuit diagram
- New fast charging I constant current source charging circuit
- Comparative circuit diagram of various VI conversion and constant current sources
- Constant current source drive circuit
