Home >
Power Circuits >Charging Circuits > Smart pulse electric bicycle charger circuit schematic diagram
Source: InternetPublisher:ghaytweyhtoo Updated: 2013/01/02
Voltage-driven pulse width modulator TL494 1. Characteristics and functions of TL494 TL494 is a voltage-driven pulse width modulator produced by Texas Instruments in the United States. It can be used as a switching power supply circuit in system circuits such as monitors and computers. The output transistor of TL494 can be connected It has two modes: common emitter and emitter follower, so you can choose double-ended push-pull output or single-ended output mode. In push-pull output mode, its two drive pulses are 180 degrees apart, while in single-ended mode , its two driving pulses are of the same frequency and phase. The internal functional block diagram of TL494 is shown below: 1IN+, 1IN-, 2IN+, 1IN- input; FEEDBACK feedback; DTC dead time control; CT timing capacitor; RT timing resistor; GND ground; C1, C2 collectors 1, 2; E1, E2 emitter 1, 2; Vcc power supply; OUTPUT CTRL output control; REF reference. 2. Application circuit
![智能脉冲电动自行车充电器电路原理图](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/3d4886cc-3c63-11ec-ac4a-086126841eb8.jpg)
Latest Power Circuits Circuits
- Build a simple buck-boost regulator and test it on a breadboard
- In-depth analysis of DC-AC converter inverter
- What kind of circuit is a voltage regulator circuit?
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- LED rechargeable flashlight circuit diagram
- Detailed explanation of 5v charger circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- Homemade low-power UPS
- USB power socket using the car battery
- The production of adjustable voltage-stabilized power supply composed of LM317
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
