ZC-2-10A 12v24v automatic charger circuit
Source: InternetPublisher:super_star Updated: 2016/09/29
Single-junction transistor BT33, C3, W1, W2 and other components form a relaxation oscillator. The pulse signal generated by it is sent to the control electrode of silicon controlled thyristor SCR1 through the isolation diode D4. Adjusting the resistance of W1 can change the trigger conduction of SCR1. Angle, that is, changing the charging current. Silicon controlled thyristor SCR2, relay J, W3, W4, D5 and other components form an automatic protection circuit when the battery is fully charged. When the voltage at both ends of the battery is charged to the upper limit set by W3 and W4, D5 is turned on and SCR2 is triggered. Pass, LED2 displays, the relay is closed, and J is switched to normally open at the same time, cutting off the control pulse concentration of SCR1, that is, stopping charging the battery. K2 is a switch for charging 12V and 24V batteries. The picture shows the switch in the 12V position.
Latest Power Circuits Circuits
- How about the boost converter TPS61299?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- A very convenient small power supply circuit to share
- ISO113 circuit that can reduce power consumption
- The constant current source composed of two transistors can drive high power
- Switching power supply circuit composition and function introduction of each part
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Converting a lithium battery charging board into a constant voltage and current charger
Popular Circuits
- STR5412 power circuit
- Laser power circuit
- Diamond differential input power amplifier power circuit
- Single LTC power circuit
- Karaoke light controller circuit (1)
- Music power circuit
- Practical neon light power circuit
- Common power circuits and applications 04
- 6.3V, 270V, 300V DC power supply circuit
- Small power UPS power circuit and production
