Light control, single button switch wall base circuit
Source: InternetPublisher:失踪的猫 Updated: 2015/02/06
During the day, due to the high indoor brightness, the switch load (relay) does not work when the button is pressed. At night or when the indoor brightness is dark, the load can start working by pressing the button switch. This means that whether the load starts after pressing the button depends on the brightness of the room. Once the load is started, regardless of the brightness of the room, However, pressing the key switch again can turn off the load. PR is the brightness control and adjustment resistor. You can also increase or decrease the resistance value as needed. The photoresistor should be installed in a position that is not blocked when the button is pressed (if possible, try to install it in a place that cannot be artificially blocked). Otherwise, when the indoor brightness is high, the load will start accidentally after pressing the button.
![光控、单按键开关壁座电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4cd26a4c-3c63-11ec-b417-086126841eb8.gif)
Latest Control Circuits Circuits
- Model rocket launch controller circuit
- Tutorial on making your own remote-controlled robotic arm
- How to remotely control devices using ESP8266 and LPC2148
- Build a glove-controlled robotic arm
- DIY an electromagnetic levitation device
- How can we make the robot move precisely on a predefined path?
- Design and production of wireless multi-location control switch circuit
- Do-it-yourself trial production of phase failure protection device
- Electric vehicle battery charging protection circuit
- Motorcycle anti-theft device circuit design
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
