Simple power outage self-locking switch circuit
Source: InternetPublisher:偷熊计划 Updated: 2010/10/22
When the power supply from the power grid is normal, it is used like an ordinary switch. Press K1, and the 220V AC power will be divided by R1 and R2 to provide a trigger voltage to the triac, causing the triac to conduct. After the thyristor is turned on, during the positive half cycle of the power supply voltage, a small amount of current charges C through R4 and D, and at the same time the thyristor is triggered by the voltage division of R3 and R2; during the negative half cycle, C discharges to R3 and R2 and triggers the bidirectional SCR, so that the bidirectional thyristor continues to conduct, ensuring the normal operation of the load. Once the power grid suddenly loses power, the charge on C is discharged through R3 and R2. After the power grid is restored, since K1 is normally open and there is no voltage on C, the triac cannot be triggered to conduct, and the circuit is in a disconnected and self-locking state, so no current flows through the load. Only by pressing K1 again can the load work normally, thus effectively preventing waste and accidents caused by restoring power after a power outage. Normally closed button K2 is used to turn off the circuit under normal power supply conditions.
![简单的停电自锁开关电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4e082fb6-3c63-11ec-86e2-086126841eb8.jpg)
Latest Control Circuits Circuits
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- Tutorial for building a remote-controlled Arduino Air-Boat
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor control circuit for starting and running without phase loss
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of voice control circuit
- Audio interface protection circuit
- A novel and practical power line anti-theft and cutting alarm circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
