Automatic delay lighting switch circuit
Source: InternetPublisher:奥特man123 Updated: 2019/08/17
When leaving a room at night, always turn off the lights first. But if the light switch is not at the door, it is very inconvenient to turn off the light and then walk to the door in the dark. The switch introduced in this article uses only 9 components and can be easily added to the original switch to delay your lights for tens of seconds after being turned off, giving you enough time to leave the room and avoid being caught in the dark. bitter. Working principle: The circuit principle is shown in the figure below. A and B are connected to both ends of the original switch respectively. When the switch S is closed, the positive half cycle of the alternating current passes through D6, R2, R1, D1 and the thyristor control electrode, triggering the thyristor to conduct; the negative half cycle of the alternating current passes through D4, R2, R1, D1 and the thyristor control electrode. , triggering the thyristor to conduct. After the thyristor is turned on, it is equivalent to short-circuiting points C and D, so points A and B are also closed through the diode and the turned-on thyristor. At this time the light is on.
After the switch S is turned off, because the capacitor C1 is discharged through R1, D1 and the thyristor control electrode, the thyristor still has a trigger current to maintain conduction. The discharge current gradually decreases. After a period of time, the thyristor is cut off and the light goes out. The delay time of this circuit is about 40 to 50 seconds. Component selection: Choose a thyristor with a maximum current of 1A and a withstand voltage of 400V. D1, D3~D6 can use 1N4004. C1 uses a color TV capacitor with a voltage of 630V and 35μF. If the S light does not light up when the switch is turned on, the resistance of R1 can be appropriately reduced.
![自动延时照明开关电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4ea49910-3c63-11ec-8222-086126841eb8.jpg)
Latest Control Circuits Circuits
- DIY a simple fire alarm
- Tutorial on making your own remote-controlled robotic arm
- How to remotely control devices using ESP8266 and LPC2148
- How to Make a Simple Chicken Incubator
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What are the challenges in designing a permanent magnet linear generator?
- Squirrel cage asynchronous motor reverse braking control circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and analysis of wire control circuit
- Water supply reminder after water outage
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
