Infrared heater temperature control circuit
Source: InternetPublisher:念念Brown Updated: 2013/03/11
In the severe cold winter, infrared heaters become household heating equipment. Most of their heating tubes are composed of three to four. Each heating tube is controlled by a switch. The temperature is controlled by a selector switch. The temperature control is extremely uneven. This circuit can enable all heating tubes to be used at the same time and achieve stepless adjustment. Working principle: The circuit is as shown in the figure above. IC (555) is connected as a low-frequency oscillator. Adjusting RP can change the charge and discharge time constant of C3. The output pulse duty cycle of pin ③ of the IC changes accordingly, that is, the thyristor's The ratio of turn-on and turn-off times controls the average power obtained on the heating tube RL to achieve the purpose of temperature control. When RP is adjusted to the uppermost end, the IC output pulse duty cycle is approximately "0", and the power obtained on RL is the smallest; when RP is adjusted to the lowest end, the IC output pulse duty cycle is approximately "1", and the power obtained on RL is Maximum power. Therefore, adjusting RP can make the IC output pulse duty cycle continuously change between "0" and "1". What is obtained on RL is the average power that continuously changes between the maximum and minimum, and the LED brightness changes accordingly as the average power. Size indication. This thermostat can also be used as a power regulator in other resistive heating appliances without generating electromagnetic field interference. The choice of the power of the thyristor depends on the power of the heating tube. Generally, the heat extractor of 1KW ~ 1.5KW can use the thyristor of BTA12/600, and it is better to add a heat sink.
![红外取暖器温度控制电路](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/4fcd17d8-3c63-11ec-a0c0-086126841eb8.jpg)
Latest Control Circuits Circuits
- How to build a simple tachometer using an infrared reflectance sensor
- Introduction to the internal structure of the Delta winding motor
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Manual automatic air compressor control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Simple phase failure protection circuit composed of intermediate relay
- Add one more component to improve the phase failure protection function
- Design and principle analysis of practical electric curtain remote control device
- Electric vehicle battery charging protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
Popular Circuits
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
