Color TV simple protection socket circuit
Source: InternetPublisher:萌面大虾 Keywords: Protect sockets electrical appliance protection Updated: 2011/06/21
Simple Protective Socket for Color TV Currently, the power supply for color TVs is an electronic switching power supply. When the mains voltage is out of phase and results in a 380V voltage input, the action speed of the protection device must be faster than the working speed of the electronic switching power supply to be effective. Protect the color TV from being damaged. However, some color TV protectors currently on the market cannot do this. Even if the color TV protection device is installed, accidents of burning out the color TV due to the wrong phase of power supply often occur. The reasons are mostly Before the protector has acted, the color TV has been damaged. The simple protection socket introduced in this article can quickly act to blow the fuse under phase misalignment conditions, effectively protecting color TVs. (Webmaster Tip: In fact, this device can be applied to any other mains-powered equipment, such as computers, audio, etc.; following this principle, netizens can design other protection devices that meet their own needs according to their needs) Working Principle
It is composed of the main components - varistor MY and triac VS. The main function of MY is to absorb power grid clutter pulses and prevent large current impacts at the moment of startup. Since it is at the first pass of the color TV power supply, it has the effect of purifying the power grid, reducing interference, and making the screen image clearer; VS is an electronic The switch can quickly turn on when the power grid is out of phase to generate a strong short-circuit current that blows the fuse FU, thereby cutting off the power supply to the color TV. The specific working process is as follows: When the mains power grid voltage is normal, VS is in a cut-off state due to insufficient trigger current, and the color TV is powered and works normally. Once a phase misalignment accident occurs, the input voltage will rise to 380V. At this time, VS is quickly triggered to conduct. At the moment of phase misalignment, due to the voltage dividing effect of R2 and R3, the voltage input to the color TV is only UO = Ui ×R3/(R2+R3)≈230(V), this voltage value will not damage the color TV. At the same time, the conduction of VS will cause the current of the protector circuit to surge, and FU will quickly fuse and cut off the power supply. Component selection and production list are shown in the table below. No. Name Model Quantity R1* Resistor 100K 1/4W Need to adjust 1 R2 Resistor 30Ω Homemade with 500W electric furnace wire 1 R3 Resistor 47Ω Homemade with 500W electric furnace wire 1 MY Varistor 330V 1 VS Triac 3A/600V 1 FU fuse 3A 1 CZ power socket 10A/250V 1 During debugging, use a 1kW coupling transformer to adjust the mains voltage to about 300V, and connect its output to Ui of the device (Note: Do not insert any electrical appliances into CZ during debugging!) Adjust the size of R1 so that VS is just turned on and FU is blown. After debugging is completed, it means that the protective socket is working normally.
- A simple magnetic switch circuit sharing
- The meaning and importance of circuit protection, common types of circuit protection
- Use your smartphone to turn on/off the power in your home
- Controlling LEDs with Node-RED in Raspberry Pi
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- DIY an electromagnetic levitation device
- Squirrel cage asynchronous motor reverse braking control circuit
- Magnetic door and window anti-theft alarm
- Water supply reminder after water outage
- Multi-channel patrol detection control circuit b
- Photocell trigger control circuit
- Mobile phone camera flash control circuit
- Table printing machine control circuit
- Schematic diagram of motor PLC control circuit
- 24h automatic switching capacitor control circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Timing and fire power control circuit
- Forward and reverse control circuit of micro DC motor b
- Temperature measurement and control circuit
