Transceiver circuit diagram of single-channel power line communication
Source: InternetPublisher:MartinFowler Keywords: Single channel power electrical circuit power line communication Updated: 2021/07/23
This circuit is a single-channel power line communication transceiver application circuit. It uses the mains 380V or 220V low-voltage power lines to transmit analog and digital signals for wired communication. Figure (a) is a single-channel power line carrier transmitting circuit, and its core component ICl is the audio phase-locked loop integrated circuit LM567; Figure (b) is a single-channel power line carrier receiving circuit.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Fabrication of multi-cell lithium battery charging circuit
- Introduction and principle analysis of switching regulated power supply
- Energy-saving motorcycle rectifier regulator
- Visible laser digital control modulation driver
- Driving circuit that controls LED brightness using PWM signal
- The constant current source composed of two transistors can drive high power
- LED Driver ZD1680
- LM317 regulated power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Coil short circuit tester
- STR5412 power circuit
- Power circuit of LBO-522 dual trace oscilloscope
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- led drive power circuit
- Industrial four-way programmable controller power circuit
- ±15V active servo power circuit
- Common power circuits and applications 07
- Inverter power circuit
